ND Weight Revealed - Faster than SP!
Postby Hammer » Mon Mar 16, 2015 10:01 pm
The weight of the new ND has finally been released by Mazda.
In manual form:
998kg for the 1.5 litre engine
1058kg for the 1.8 litre engine
And if the article from Carsales.com.au is to be believed, they're estimating the 0-100km/h times of the 2.0 litre, manual ND to be a brisk 6.2 seconds. On paper this is 0.1 seconds faster than the MX-5 SP (1.6 seconds faster than the NC).
Clicky Clicky
beavis
Re: ND Weight Revealed - Faster than SP!
Postby beavis » Mon Mar 16, 2015 10:20 pm
Hammer wrote:6.2 seconds
asif.
mazda wouldn't.
they are a pack of girls.
I heard the 1.5lt was near 10secs.
lizard
Postby lizard » Mon Mar 16, 2015 10:45 pm
asif.
mazda wouldn't.
not quite as a 121 bubble car 8)
Trackphotos
Postby Trackphotos » Mon Mar 16, 2015 10:56 pm
Pretty sceptical of anything with only 109kW/tonne doing that kind of time to 100, even with the short gears that MX5s are known for. Their claim of 7sec for the 1.5L version is pretty optimistic too, I bet.
Guran
Vehicle: ND - 1.5
Postby Guran » Tue Mar 17, 2015 10:49 am
Hammer wrote:1058kg for the 1.8 litre engine
Actually that should be 1058kg for the 2.0 litre engine.
Carsales calculations of 0-100km/hr times are very dodgy. There is no chance the ND 2.0L will get close to the SP in straight line acceleration. It is also misleading to quote US figures for kerb weight as Australia is more likely to get a European spec. At the Geneva Motor Show, it was stated that the 1.5L kerb weight is 975kg and the 2.0L is 1000kg (without the 75kg driver). Those kerb weights vary depending on trim level and the local interpretation of what constitutes "kerb weight". So the 1.5L has 10.2kg/kW and the 2.0L has 8.5kg/kW. In comparison the SP has 7.5kg/kW, and it is highly unlikely that any difference in torque curve or traction is going to make up for that gulf in weight/power ratio.
OurCognitiveSurplus
Postby OurCognitiveSurplus » Tue Mar 17, 2015 11:51 am
I was quite surprised that the 1.5L was in the 9sec range to 100kmph. I've always thought that over 10seconds in ecoboxes becomes worringly slow in terms of merging and stuff. 9 seconds for a modern sports car isn't right. Toyota says the 86 can sprint from 0-100km/h in 7.6 seconds for the manual. And that's not a quick car.
For context, the new MX5 would lose a drag race to a Toyota Camry Hybrid. It's just not right.
NB8A - Twilight Blue
Trackphotos
Postby Trackphotos » Tue Mar 17, 2015 12:40 pm
OurCognitiveSurplus wrote:I was quite surprised that the 1.5L was in the 9sec range to 100kmph. I've always thought that over 10seconds in ecoboxes becomes worringly slow in terms of merging and stuff. 9 seconds for a modern sports car isn't right. Toyota says the 86 can sprint from 0-100km/h in 7.6 seconds for the manual. And that's not a quick car.
The 86 isn't an especially quick car, no. But still faster than any stock non-turbo mx5 has ever been. That 9sec range is more than enough to merge onto highways etc, it's no slower than my NB and that has no trouble. The drivers are the problem.
mattyredlocks
Postby mattyredlocks » Tue Mar 17, 2015 1:41 pm
Hold second, hold third, bam: onto the highway and your passenger is asking you to slow down.
No problems.
Because reasons.
Craig
Postby Craig » Tue Mar 17, 2015 2:02 pm
mattyredlocks wrote:Hold second, hold third, bam: onto the highway and your passenger is asking you to slow down.
No problems.
Amen to that! :beer: :BROADY:
oztrackdays
60 kg in an extra 300 cc ?
Postby oztrackdays » Tue Mar 17, 2015 2:19 pm
What else is different between 1.5 and 2.0 cars ?
Also for Reasons of repeatability They prefer the 0-100 times to be performed on a Hub Dyno
this level of traction will never be achieved under real world conditions.
Trackphotos
Re: 60 kg in an extra 300 cc ?
Postby Trackphotos » Tue Mar 17, 2015 4:11 pm
oztrackdays wrote:this level of traction will never be achieved under real world conditions.
Or non-existent wind resistance..
taminga16
Postby taminga16 » Tue Mar 17, 2015 5:26 pm
project.r.racing
Postby project.r.racing » Tue Mar 17, 2015 7:09 pm
Hammer wrote:The weight of the new ND has finally been released by Mazda.
In manual form:
Clicky Clicky
now put fluid in... :oops:
rjastra2
Postby rjastra2 » Thu Mar 19, 2015 11:36 pm
1010kg for the 1.5L Manual S special model (one up from poverty pack). 1040 for topspec leather model with MT.
So how much is the 2L model going to be? 60kg on top of the 1.5L number? 1070-1100kg.
Postby Crapweasel » Fri Mar 20, 2015 12:10 am
Don't believe the car mags is something I've discovered over the years, especially before a car has been released and tested.
Here's a site I've used a bit - seems to be within a more accurate range than one journalist's guess...
http://www.torquestats.com/modified/index.php?pid=calculator
Chuck in your kerb weight, drive type and power at the flywheel.
Have fun!
