Have a Wankel or mod the 5 or...
YanMa YatTai
Postby YanMa YatTai » Wed Mar 04, 2015 6:42 pm
Been thinking of getting an FD RX7. Would cost around $20K - $30K for a series 8. That's a lot of money. But I have lusted after one for a long time.
Or I can throw serious amounts of money at an MX5 and fix/mod it.
Or I could stretch and buy a new Toyota 86 GT. Or wait and see about the ND.
What would you do?
Trackphotos
Re: Have a Wankel or mod the 5 or...
Postby Trackphotos » Wed Mar 04, 2015 6:51 pm
YanMa YatTai wrote:Been thinking of getting an FD RX7. Would cost around $20K - $30K for a series 8. That's a lot of money. But I have lusted after one for a long time.
What would you do?
Road or track, or both? Road, 86. Track, modded MX5. Both, RX7.
Postby NitroDann » Wed Mar 04, 2015 7:01 pm
Ask to drive bear2230 s car before you decide.
Postby NitroDann » Wed Mar 04, 2015 8:00 pm
Or a similarly well setup car.
Postby bruce » Wed Mar 04, 2015 8:15 pm
FD. You said it.
Postby Lokiel » Wed Mar 04, 2015 8:37 pm
FDs are one of the sexiest cars ever made - unfortunately they're money pits too :(
SlugRacer
Postby SlugRacer » Thu Mar 05, 2015 8:27 pm
LS3 FD
Craig
Postby Craig » Thu Mar 05, 2015 8:52 pm
Lokiel wrote:FDs are one of the sexiest cars ever made - unfortunately they're money pits too :(
:BROADY:
oztrackdays
Postby oztrackdays » Thu Mar 05, 2015 9:14 pm
I have had multiple mx5 and multiple FD's. For track work go a 5. If you are a bogan street join boost whore go the FD. I am daily driving my FD it gets about 35 liters per hundred around town they can be worse.
Postby bruce » Thu Mar 05, 2015 9:58 pm
35 litres per 100!
Is the go pedal welded to the floor.
oztrackdays
Rotary Efficiency ...
Postby oztrackdays » Thu Mar 05, 2015 10:03 pm
No it just comes out the back in flames.
My old one used about 80+ Litres per 100 K's when I would track it.
Many TUNERS just use the fuel to cool the chook cooker down some to keep it alive.
For really short trips they are super inefficient on the highway @ 110 easy get about 10 L/100 k's
speed
Postby speed » Fri Mar 06, 2015 8:39 am
I have always appreciated the FD.
Microtech base map gives better economy than 35L per 100 and they are old design ecu's.
Saying that, NitroDann turbo 5 would be lighter, bloody fast and you could do it with smaller injectors, ie rx8 ones ;)
There will be many haters of rotaries on a piston based forum.
Personally I'd drive both, consider costs of mods and maintenance before making a decision. Can't wait to read which way you go. Best of luck :)
rascal
Postby rascal » Fri Mar 06, 2015 9:14 am
For the $30K you are looking at spending my choice would be a supercharged NC1 with suspension work. This would be fast and handle nicely. Nicer road car than NA/NB and still competent on the track if thats what you wanted to do.
And wouldn't be a continuing money pit like a 20yo rotary would.
MattR
Postby MattR » Fri Mar 06, 2015 10:25 am
For $30k I would look at a early Mopar, a 65 'Cuda with 273 V8, dirt cheap to go fast, and no matter what anyone says here, they can be made to handle extremely well at not a lot of cost. Just got to find somebody who understands torsion bar rear ends......
Or a 67 Mercury Cougar XR7, just like a mustang but 390ci goodness, better looking and cheaper than the equivalent mussy.
mattyredlocks
Postby mattyredlocks » Fri Mar 06, 2015 10:58 am
I'd personally go the 5, spend the difference in initial purchase cost on mods. But that's just because that's what works for me, your mileage may vary (with the RX-7, it definitely will :P)
Depends if it'll spend more time in the garage, outside cafes on the weekend, at hard parker meets or on the track. After that, it's how much money you want to spend.
It's really all about what you want to do with it, there's no right or wrong answer here.
Because reasons.
