Why hasn't the SP airbox been copied?
Seems everything else has been cloned on a MX5 so why hasn't the SP air box been copied .Is there a market ?
Re: Why hasn't the SP airbox been copyed ?
Probably only a tiny market for starters.
Those with an SP are limited (arent; there only 150 of them or so?) and people without an SP aren't really likely to want a replacement airbox since there's probably no benefit to an SP airbox over what they already have. (and most people who spend money to chance intakes do it for looks/noise)
So yeah, basically there's probably only a tiny market.
Also remember the SP was Australia only, so there won't even be an overseas market.
(personally I don't think it looks particularly nice either, the embossed "Mazda" seems a little bit chinese aftermarket to me)
Re: Why hasn't the SP airbox been copied?
Only 100 (some say 101) SPs were produced and the airbox is specific to that model and its turbo/intercooler plumbing which dictate its design.
The intercooler setup of the SP is awkward compared to many aftermarket solutions and the MSM/SE so the airbox is only desirable to those owning an SP.
- Caffeine
SMB make a carbon fibre airbox of similar design if you want one;
http://www.smb.net.au/fullexhaustsystems-mazdaMX5.htm
Works Engineering has two CF options - one NB specific (pictured in my car) and another universal that has been easily adapted by NitroDann
- Vehicle: Non MX-5
Why does someone think the airbox is so special it requires copying? it's like any other airbox out there with ducting.
project.r.racing wrote:Why does someone think the airbox is so special it requires copying? it's like any other airbox out there with ducting.
1 looks good
2 tiz quite
3 all the reasearch has been done
4 because I cant purchase a SP air box
Points 1-3 are only valid if there is no point 4.
The fact that point 4 exists makes points 1-3 redundant.
Your options appear to be rare(101), aftermarket or custom.
- smy0003
I love your work intake box apu, are you still bringing their stuff into aus?
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
I still am. That intake box is a killer though - $600-700 when I last checked and a minimum order is required.
The other one is more reasonably priced.
- smy0003
Phwoar, it is a nice looking piece of kit though.
The k&n metal pipe and filter deal is a few hundred bucks, so I'd still call the works one alright value since it's cf.
