Which lube/grease to use during brake pad replacement?
magenb
Postby magenb » Fri Jan 23, 2015 10:18 pm
Any recommendations on which lube to use on the slider pins & piston? And which grease on the backing plates?
Re: Which lube/grease to use during brake pad replacement?
Postby hks_kansei » Sat Jan 24, 2015 8:33 am
Piston should be fine as it is, no need to lube unless you've disassembled the caliper.
Slider pin you need a high temperature grease, it's not particularly important what kind, just look on the label for something sutiable for brakes (I use "Sylglide" on mine)
I've never greased backing plates.
Postby manga_blue » Sat Jan 24, 2015 9:05 am
x2 Find a brake caliper synthetic grease, not a rubber grease, for the sliders. I never grease the pads or backing plates, it just introduces a risk of contamination.
I've used this one for years with no problems. It's marketed as Sta-lube or CRC, pretty common in auto shops.
MattR
Postby MattR » Sat Jan 24, 2015 4:30 pm
Some brake pads will have some slider pin grease included.
The Hawk pads I order direct from Hawk in the States have a couple of little bags of grease for the slider pins in the box.
Postby manga_blue » Sat Jan 24, 2015 6:37 pm
I've used the Hawk grease. The sliders started binding after a couple of track days.
sailaholic
Postby sailaholic » Sat Jan 24, 2015 7:43 pm
Repco suppliede with a tube of bendex grease. Can't comment on how well it stands up under track applications though.
