1996 Mazda Miata 1.8L DOHC Won't Start Need Help!!!
langlsha0
Postby langlsha0 » Mon Jan 12, 2015 1:24 pm
As title says I have a 96' miata 1.8l, I purchased the car with a bad miss at idle that would clear at 1200rpm's and rand great above those rpm's it also occasionally idles below 500-200rpm. So I pulled the "CEL" codes and only one was showing EGR orifice tube restricted so I cleaned out the egr pipe from header and replaced egr. I also recently did a tune up (plugs, wires, and oil change and air filter. Car still has a miss at idle and takes a few cranks to start when it's cold such as less then 28-32 degrees, and here recently has decided not to start at all. So I checked spark on all 4 cylinders all ok, turns out my fuel pump isn't turning on so I went to the under hood diagnosis and put a jumper wire from the f/p to the gnd (fuel pump and ground) now when I cycle key fuel pump turns on and runs fine, so I unplugged the relay while pump was going and it shut off, plugged it back immediately came back on. So I'm now trying to figure out what would keep my fuel pumping from turning on? And is their a way to check the relay with a ohms meter. Any help is appreciated thanks in advance!!!!Image
Sent from my iPhone
Re: 1996 Mazda Miata 1.8L DOHC Won't Start Need Help!!!
Postby Magpie » Mon Jan 12, 2015 4:27 pm
CAS sensor. Do you have a noid light or some way of testing that the injectors are firing?
greenMachine
Postby greenMachine » Mon Jan 12, 2015 7:02 pm
Haven't we been here recently?
I suggest you try someone a bit closer ... who might know something about the eccentricities of lhd 'miatas' ... :wink:
:mrgreen:
smy0003
Postby smy0003 » Mon Jan 12, 2015 8:23 pm
It may be because your steering wheel is on the wrong side.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
