NC power limits with stock engine and fuel system
magenb
Postby magenb » Thu Dec 18, 2014 9:47 am
Hi Guys,
Just looking to get a bit more power out of an 06 NC, but don't really want to go changing injectors/fuel pump etc. Any one know how much power you can safely put through the stock system?
Re: NC power limits with stock engine and fuel system
Postby Regie » Thu Dec 18, 2014 12:58 pm
forced induction or staying NA?
magenb
Postby magenb » Thu Dec 18, 2014 1:18 pm
Regie wrote:forced induction or staying NA?
How much I can get out of the stock system would lead me down that path, for instance, if I'm going to be topping out at around 150 wrhp then there's no point in going forced.
Postby Regie » Thu Dec 18, 2014 3:23 pm
A set of headers with full exhaust and a tune will get u between 110-115rwkw. That's probably the limit without opening up the engine.
Forced you are looking at upto 170-180rwkw. But you'll need to upgrade fuel system for that
Postby Mr Morlock » Fri Dec 19, 2014 12:59 pm
modest changes will add modest KW- if you got 10% more you would be doing well I would have thought.
