Number {Plate Mounting (Front)
MXMatt
Postby MXMatt » Thu Jul 31, 2014 9:29 pm
Hi All,
On my little MX the PO mounted the full size number plate in the open mouth, I would rather move it back to the original position which I assume is on the nose center to the car???
Does anyone have a picture of the original mount or selling one?
M@
emx005
Re: Number {Plate Mounting (Front)
Postby emx005 » Thu Jul 31, 2014 9:54 pm
Drill two holes at the bottom of the front plate and keep the current mount. The original mount is horrible!
MXMatt
Postby MXMatt » Fri Aug 01, 2014 7:50 pm
Thanks EMX005,
I am switching to a slimline plate for the front and really wanted to mount it on the bar, short of just drilling holes in the nose, I was trying to find out how the originals were mounted
M@
Postby Mr Morlock » Fri Aug 01, 2014 8:04 pm
you can mount a slimline plate in the nose and use the standard bracket invert it- and its a big improvement over having the thing suspended in front of the bodywork. My recollection was to use an aluminium rhs piece as a spacer to position the bracket / plate - drill holes in the alu rhs and use the same mount points as the original. It does not interfere with cooling. Take a look - have a bit of head scratch make a cup of coffee and its an easy job.
MXMatt
Postby MXMatt » Fri Aug 01, 2014 8:53 pm
Thanks will do just that next weekend maybe - I also want to add Fog lights in the mouth and was concerned with air flow / overheating
M@
Nevyn72
Postby Nevyn72 » Fri Aug 01, 2014 9:52 pm
You want one of these!
(top one in the link, from either Mania (linked) or Automotive+ in Qld)
http://www.mx5mania.com.au/product1825.htm
This is what it looks like fitted. :wink:
Postby KevGoat » Fri Aug 01, 2014 10:32 pm
MXMatt wrote: - I also want to add Fog lights in the mouth and was concerned with air flow / overheating
M@
Noooo!! :shock:
Looks awful! First things I removed when I got mine home ....
Postby Mr Morlock » Sat Aug 02, 2014 12:08 pm
the trouble with that mounting is that a minor push on the plate can end up scratching / damaging the paintwork.
smy0003
Postby smy0003 » Sat Aug 02, 2014 2:30 pm
Mr Morlock wrote:the trouble with that mounting is that a minor push on the plate can end up scratching / damaging the paintwork.
Yep, the last thing you want is a scratch on the nose of your car, found out a bit too late though.
Mine's offset now:
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
MXMatt
Postby MXMatt » Sat Aug 02, 2014 7:52 pm
LOL Thanks guys,
The way it was previously mounted has damaged all the paint at the lower edge of the opening, (Gives me an excuse to repaint the bar when I get a lower lip!) - the one shown by Nevyn72 is exactly what I am after! many thanks
I drive over 125klm each way to work 5 days a week and through some pea soup fogs for four or five months of the year so fog lights are a safety thing as much as anything else - I was thinking of fitting the lower half of an NB bumper - but that is a lot of work for a similar outcome - now I just have to find some fog light brackets and good to go!!!
M@
smy0003
Postby smy0003 » Sat Aug 02, 2014 8:54 pm
I love the look if the lights in the air dam.
Eye of the beholder and all that junk, I guess.
