I think I saw a turbo in the ND
tescoking
Postby tescoking » Fri Jul 11, 2014 3:05 pm
Not sure have you guys seen this before, but I just accidentally found this article, it was posted in March, some of you might see this before.
http://jalopnik.com/step-inside-the-ugl ... 1571275617
My 5
Odd
Re: I think I saw a turbo in the ND
Postby Odd » Fri Jul 11, 2014 4:20 pm
Could it have a diesel?
I also have a mazda6....almost bought the diesel, the one I drove got along very well!!
http://www.mazda-news.eu/2014/06/11/nex ... an-diesel/
You can't demand respect....you have to earn it
NA8 for Fun, CX5 for carrying crap...;)
Postby Regie » Fri Jul 11, 2014 4:54 pm
Old news
I reckon that will be the platform for the Fiat version, The MX5 will get a 2l NA motor :D
Odd
Postby Odd » Fri Jul 11, 2014 5:22 pm
From Mazda site
http://www.youtube.com/watch?v=0C9OLDIRLeI
Could the cartoon showing a sky active diesel in a open car be a hint???
tescoking
Postby tescoking » Fri Jul 11, 2014 5:48 pm
I prefer no turbo, otherwise it will destroy thr responsive of this car :D
And if I want turbo, I believe after market is better than factory turbo.
My 5
Odd
Postby Odd » Fri Jul 11, 2014 6:00 pm
what about a turbo diesel....lots of torque= acceleration
Dan
Postby Dan » Fri Jul 11, 2014 6:27 pm
tescoking wrote:I prefer no turbo, otherwise it will destroy thr responsive of this car :D
Turbo is less responsive??
I'll be unhappy with a turbo if they put a tiny engine in it and ruin the top end. Would be cool though if they released a base model 2L and then a 2L Turbo or a 2.5L 'SP25'.
davekmoore
Postby davekmoore » Fri Jul 11, 2014 8:31 pm
2.2 turbo diesel auto with paddles for me then please. And an LSD to help with all that lovely torque.
tescoking
Postby tescoking » Fri Jul 11, 2014 11:38 pm
Isn't it diesel has less fun? Also not many people know how to service and fix
My 5
deviant
Postby deviant » Sat Jul 12, 2014 12:04 am
Nah. Diesels are no more scary than any other modern engine.
I would be very happy with something 1.6-2.0 and turbocharged. The latest generation turbo cars are really something else...small capacity engines that through a process of black magic and voodoo make the power and torque that 2.0 engines used to make but with half the fuel consumption. There is no good reason for the new MX5 to be anything less than a 1.5l turbo engine with 150KW, 230NM and capable of 7000RPM with power and torque spread from 1800RPM.
davekmoore
Postby davekmoore » Sat Jul 12, 2014 8:34 am
tescoking wrote:Isn't it diesel has less fun? Also not many people know how to service and fix
Come and test drive a Mazda 6 or CX5 2.2L diesel back to back with a 2.5L petrol.
And note that nearly every manufacturer has at least one diesel motor now, in addition to all the commercial applications out there, so there are no servicing issues.
rjastra2
Postby rjastra2 » Sat Jul 12, 2014 10:19 am
Why compare a normally aspirated 2.5L petrol to a turbo diesel? .... and a 10% larger than the class standard (2L TDI) at that.
Go check the difference in weight between the 2.5L Mazda 6 and the turbo diesel. Thats the extra weight a MX5 diesel would carry around
davekmoore
Postby davekmoore » Sat Jul 12, 2014 8:50 pm
Because facts, correctly presented and in context, help further constructive debate.
Some examples here:
Diesel weighs 70kg more.
2.5L petrol 250 Nm @ 3,250 rpm. 2.2L diesel 420 Nm @ 2,000 rpm. Diesel has 68% more torque at 60% of the revs.
2.5L petrol 138 kW @ 5,700 rpm. 2.2L diesel 129 kW @ 4,500 rpm. Diesel has 93% of the power at 79% of the revs.
I make the 2.5L petrol and 2.2L diesel comparison because it's the only possible petrol/diesel one within the Mazda range.
TTT
Postby TTT » Sun Jul 13, 2014 1:39 pm
Diesel in an mx5? Have you people lost your minds?
Mx5 isn't about torque or fuel consumption or power at low revs...
The sound and revs and driving experience is what the car is about.
I've got a cx5 td for my daily.
Yes it is more comfy and uses less fuel than my na6.
But that is not what an mx5 is about.
Td engines are horribly agricultural things.
Would ruin the enjoyment that a somewhat revvy light mx5 brings.
Someone mentioned responsiveness of an NA engine over turbo... I assume that should have said throttle response... And I totally agree.
Sure no power but also no lag. Each mm of throttle movement equals engine response.
davekmoore
Postby davekmoore » Sun Jul 13, 2014 2:00 pm
TTT wrote:Diesel in an mx5? Have you people lost your minds?
Only me. I accept complete responsibility. My rego is BARMY after all (in Pommieland it confirms I have indeed lost my mind).
