Gearbox shifter boot help needed
mx589
Postby mx589 » Mon May 26, 2014 6:34 pm
Hey guys I'm a bit of a noob here so don't know if I posted this in the right spot or not but I am fitting a nb 6 speed to my na and want to replace both the upper and lower boots. I've done a little bit of research but want to know before I buy it will the boots in the link below fit and is the price not bad ?
Thanks
http://www.ebay.com.au/itm/321021406439
aka_juffa
Re: Gearbox shifter boot help needed
Postby aka_juffa » Mon May 26, 2014 6:45 pm
Yes, will fit and price is good.
davekmoore
Postby davekmoore » Mon May 26, 2014 7:43 pm
Make a photographic note of the order in which the shifter components are fitted. Be very careful to avoid small parts falling in to the tunnel. Let me know if you need a replacement bottom bush (the one that fits on the ball at the bottom of the shifter) as I have a couple of brand new unused spares.
mx589
Postby mx589 » Mon May 26, 2014 7:57 pm
Thanks for the info guys.
How much you want for one of those bushes davekmoore?
greenltd
Postby greenltd » Mon May 26, 2014 8:31 pm
I've wondered about doing the same gearbox change myself. I'm interested in peoples thoughts on how worthwhile the swap is?
Sent from my AMID-9743G using Tapatalk
davekmoore
Postby davekmoore » Mon May 26, 2014 9:11 pm
PM sent.
Postby 93_Clubman » Tue May 27, 2014 11:54 am
greenltd wrote:I've wondered about doing the same gearbox change myself. I'm interested in peoples thoughts on how worthwhile the swap is?
Most, if not all, that do it seem happy, but cost @ $1k for 6 speed GB plus removal/fitting, & 6 speed GB feel compared to 5 speed GB feel might be considerations.
