OBDII Codes
Posted: Fri Apr 11, 2014 12:59 pm
by Sailor
I've found a great resource for OBDII codes.
Not only does it give you the description of the code, it also gives advice on fixing the problem.
http://www.samarins.com/diagnose/codes.html
Re: OBDII Codes
Posted: Fri Apr 11, 2014 1:25 pm
by lizard
:beer: :beer: :beer:
Re: OBDII Codes
Posted: Fri Apr 11, 2014 1:46 pm
by bootz
So they use the same code sequence for all makes and models and year of manufacture :?:
Re: OBDII Codes
Posted: Fri Apr 11, 2014 5:34 pm
by Sailor
These are the generic codes that will cover most problems you are likely to see, there are other manufacturer specific codes
