I've found a great resource for OBDII codes.
Not only does it give you the description of the code, it also gives advice on fixing the problem.
http://www.samarins.com/diagnose/codes.html
OBDII Codes
OBDII Codes
Rob
- bootz
Re: OBDII Codes
So they use the same code sequence for all makes and models and year of manufacture
Re: OBDII Codes
These are the generic codes that will cover most problems you are likely to see, there are other manufacturer specific codes
Rob
