Query about windscreen wipers control arm
Postby Danny » Sat Mar 01, 2014 10:16 am
Recently bought an NB. The manual says I should be able to push the wiper control arm forward for a single sweep of the blades. Does this feature work on others' cars, if so mine must be broken.
Nevyn72
Re: Query about windscreen wipers control arm
Postby Nevyn72 » Sat Mar 01, 2014 11:03 am
dvr wrote:Recently bought an NB. The manual says I should be able to push the wiper control arm forward for a single sweep of the blades. Does this feature work on others' cars, if so mine must be broken.
Thought the same with mine when I first got it....
The movement is actually more a 45 degree up + forwards motion.
At first it didn't work but after a little while it did, switch was probably a little sticky and/or non-responsive from a lack of use!
Vat
Postby Vat » Sat Mar 01, 2014 11:06 am
Nevyn72 wrote:The movement is actually more a 45 degree up + forwards motion.
Was about to post literally the same thing about the motion.
Also, only works from the top most "Off" position.
'98 Evo Gold NB8A
QR-Clubman 66.5109|Sprint 63.3635|Sportsman 67.4673|National 92.3481|Lakeside 65.7478|MP K 1:35.382|MP E 1:16.422|NM 1:08.017
Postby Danny » Sat Mar 01, 2014 10:30 pm
Thanks guys. Working properly after a few goes and with a 45deg upward push.
