Where is my 1994 NA8 Engine number?
booki89
Postby booki89 » Fri Feb 28, 2014 5:33 pm
With my vicroads inspection slowly drawing near, I need to know where the engine number is!
Mechanic's couldn't find it...
From the general reading, its at the back of the engine, under the plenum? Honestly, just confused. The manual with the car is no help either!
Can you actually read it with the engine in the car ?
Can anybody shed some light so I can get my little baby on the road :)
JBT
Re: Where is my 1994 NA8 Engine number?
Postby JBT » Fri Feb 28, 2014 5:42 pm
Top of the block near the oil dip stick. You may need a strong light and something to make the letters and numbers show clearly.
booki89
Postby booki89 » Fri Feb 28, 2014 6:07 pm
Are you referring to this
booki89
Postby booki89 » Fri Feb 28, 2014 7:06 pm
Sorry to sound dumb, but I still cannot find it...
JBT
Postby JBT » Fri Feb 28, 2014 9:26 pm
It is on the left (passenger) side at the rear. Opposite to the B6 engines.
booki89
Postby booki89 » Fri Feb 28, 2014 9:29 pm
Think I have found it!
Just near the dipstick as JBT said - but its extremeley hard to read. Looks like its covered in some spot rust? Tried to get a rag in there to clean it.... any tip's? Don't want to damage the number. Then I think i'd be in big trouble...
Don't want to go to vicroads, then they knock me back because they cannot "read" it -_-
JBT
Postby JBT » Fri Feb 28, 2014 9:33 pm
Toldya it was hard to see. Try some WD40 to clean the area and then rub some chalk on the number. I think it starts with "BP".
project.r.racing
Postby project.r.racing » Sat Mar 01, 2014 5:58 pm
booki89 wrote:Are you referring to this
B6 intake side as pictured
BP exhaust side
project.r.racing
JBT wrote:Toldya it was hard to see. Try some WD40 to clean the area and then rub some chalk on the number. I think it starts with "BP".
BP is correct.
booki89
Postby booki89 » Sat Mar 01, 2014 6:01 pm
Took off the heatshield for the extractors. Gave it a clean as best as I could. Could just make it out. Put the shield back on, and now its hard go read again. FML.
Didn't try the chalk technique though, thinking I might have to go buy some chalk!
Anybody else have some advice?
project.r.racing
Postby project.r.racing » Sat Mar 01, 2014 6:07 pm
yeah - remove surface rust.
booki89
Postby booki89 » Sat Mar 01, 2014 6:09 pm
Have heard of people sanding off the numbers...I don't wanna do that :/
What grit paper you think?
sailaholic
Postby sailaholic » Sat Mar 01, 2014 6:18 pm
Try a kitchen scourer such as the green pads, or the steel wool as a step up.
project.r.racing
Postby project.r.racing » Sat Mar 01, 2014 6:51 pm
those or WD40 and your finger.
booki89
Postby booki89 » Sat Mar 01, 2014 6:54 pm
Tried the old wd40 on finger. Only for me so far, might grab some fine sandpaper and see how i go. Fresh outta the kitchen scrubbing gear
