Chu engine sounds?
ess
Chu engine sounds?
Postby ess » Thu Feb 27, 2014 8:13 pm
When I change gears at about 4-5k revs, especially going from first to second gear, it sounds like the exhaust or engine makes a "chuu" sound. It's a NA6 non turbo, but it kinda sounds like a blow-off valve or something..
Cheers! :beer: :NA6:
PB
Re: Chu engine sounds?
Postby PB » Thu Feb 27, 2014 9:00 pm
Hmmm, you definitely have a problem. Mine goes zoom zoom
2002 Crystal blue NB8B. Sold, but where's she now???
2007 Radiant Ebony LE. Sold, and then resprayed nardo grey :roll:
2001 Crystal blue NB8B
zero00
Postby zero00 » Thu Feb 27, 2014 9:06 pm
I don't take mine to 4000 in first, I use it only to get started - 2nd? well 7000rpm is fine!
Roger D-SUNSHINE COAST
ess
Postby ess » Thu Feb 27, 2014 9:07 pm
Oh, mine goes zoom zoom, it just sounded funny and I never noticed it before! Sounds beautiful at 6k revs. <3
ess
Postby ess » Thu Feb 27, 2014 9:09 pm
What happens if i rev it up to the red line?
Postby Magpie » Fri Feb 28, 2014 6:29 am
ZOOM ZOOM or BANG BANG or wheeeee-yooooooo........
Mine at 8,200 in 3rd is doing 110 and the sound is addictive.
ess
Postby ess » Fri Feb 28, 2014 8:30 am
I love your onomatopoeia's hahaah. :')
mattyredlocks
Postby mattyredlocks » Fri Feb 28, 2014 9:49 am
ess wrote:What happens if i rev it up to the red line?
Car goes faster.
Because reasons.
deviant
Postby deviant » Fri Feb 28, 2014 10:16 am
It means it is being dríven correctly. My NB regularly sees the redline in first gear and often hits the revlimiter in other gears and because it is supercharged with a recirc valve it makes funky noises on lifting off.....GRRRRAAAAAAAAAHHH-FAP-FAP-FAP-FAP-FAP....FOOOOOTUTUTUTUTUPIGEON
No idea what your noise is, could be a vacuum leak somewhere.
Postby bruce » Fri Feb 28, 2014 1:53 pm
Methinks that noise is a small leak in your exhaust system (I get the same). Just listen from what area the noise is coming from and have a look at your exhaust (usually a small corroded spot on a join).
Postby Magpie » Fri Feb 28, 2014 2:04 pm
This threads needs more onomatopoeia! Is the sound you hearing like a fwung fwung or a hisha hisha or puhVRooPuhHoo puhVROOpuhHOO?
CatchyD
Postby CatchyD » Fri Feb 28, 2014 4:11 pm
Unsure if everyone here is being sarcastic or I'm just not understanding the "chu" sound he is getting....
I know the stock CAI this beautiful engine has makes a nice noticeable induction noise specially around the 4-5k range.
My other car has a really quite CAI but this one is nice and loud! (Haven't even put the Mania CAI in yet :twisted: )
P.S. Drive the car through a tunnel, done this many times while heading to MX5 Plus this week and oh my the sound is beautiful!
Postby Magpie » Fri Feb 28, 2014 4:38 pm
CatchyD I do that! I just slow down and then just accelerate up to the speed limit, rinse repeat! I may have to do that tomorrow on the way up to Plus.
CatchyD
Postby CatchyD » Fri Feb 28, 2014 4:56 pm
That's exactly what I do! Off the gas, on the gas, off the gas, on the gas, etc.
