1.5kg FIRE EXTINGUISHER @ ALDI
taminga16
Postby taminga16 » Fri Dec 06, 2013 10:10 pm
A friend has just sent me this prompt, apparently they are on sale tomorrow, $20.00.
Greg.
Re: 1.5kg FIRE EXTINGUISHER @ ALDI
Postby fastfreddygassit » Fri Dec 06, 2013 10:30 pm
good price :BROADY:
Postby Regie » Fri Dec 06, 2013 11:28 pm
and metal bracket
very good price
Postby Okibi » Sat Dec 07, 2013 2:16 am
Not the best looking bracket.
Make sure you take it out of the box and check it.
Last time I was buying a fire extinguisher every one on the shelf at Bunnings was on recharge/refill.
MattR
Postby MattR » Sat Dec 07, 2013 10:07 pm
And give then a slow tip over 180 degrees to make sure the powder hasn't compacted so if you do need to use it all you get is high pressure air to make the flames bigger.
In fact any one with an extinguisher, check them every three months or so by slowly rotating them to get the powder moving so it isn't compacted.
Silvia
Postby Silvia » Thu Dec 12, 2013 8:42 am
Good tip - thanks
Silver Nomad
2002 NB8C
M1474
Vehicle: ND - Turbo
Postby M1474 » Thu Dec 12, 2013 10:55 am
Repco have a 1kg with steel bracket for $16 ATM.
GHETTOCET
