Injector Dynamics Injector 1000cc, 60mm long, 11mm >!NB8A!<
Rasputin
Vehicle: NB8A - Turbo
Postby Rasputin » Mon Dec 02, 2013 7:35 pm
http://www.adaptronic.com.au/product-ca ... -dynamics/
Which injector is a correct plug and play injector for the NB8A?
Injector Dynamics Injector 1000cc, 60mm long, 11mm diamater.
Correct???
Cheers!
Dan.
timk
Re: Injector Dynamics Injector 1000cc, 60mm long, 11mm >!NB
Postby timk » Mon Dec 02, 2013 10:12 pm
Yes, those ones are correct. You'll need to remove the lower isolator washer if it is fitted, it will then look like mine pictured here:
Note that although the overall length is still longer than the factory injectors, the top spacer slides into the rail deeper and isn't a problem.
The ID725 injectors are more linear than the ID1000, depending on your goals they might be a better choice?
