NA Aluminium Bonnet/Boot
Jash
Postby Jash » Thu Oct 17, 2013 5:56 pm
MX5 Humans,
Tried searching for this to no avail.
Pretty sure my Jap NA6 has neither, which models came with them?
Many Thanks,
Jeff
sailaholic
Re: NA Aluminium Bonnet/Boot
Postby sailaholic » Thu Oct 17, 2013 6:02 pm
All came with aluminium bonnet, none came with aluminium boot from factory as far as I'm aware
Magnet will tell you what you've got.
What's with the mx5 humans thing? Just a way around saying hi guys / girls?
Sent from my iPhone using Tapatalk - now Free
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Thu Oct 17, 2013 6:24 pm
There is a limited edition in Japan that had a alloy boot as well, you can get a after market steel bonnet that is way cheaper and heavier than the original alloy bonnet.
Jash
Postby Jash » Thu Oct 17, 2013 6:42 pm
Thanks for the info guys, and yes I don't mean to assume that everyone in here is a dude.
Limited edition explains the alloy boot costs that I've seen...
wassup
Postby wassup » Thu Oct 17, 2013 6:55 pm
The aluminum boot lid you're talking about came off a M2 1028 model with a run of 300 in Japan
http://translate.google.com/translate?u=http%3A%2F%2Fwww.geocities.jp%2Fclubm2_hp%2Farchive%2Fcat28.html&sl=ja&tl=en&hl=en&ie=UTF-8
This is how it compares to a standard NA bootlid and its about half the weight too.
1990 NA6
Civic Type R
Jash
Postby Jash » Thu Oct 17, 2013 6:57 pm
Oh my. Cleanup aisle 4.
ultim8m
Postby ultim8m » Thu Oct 17, 2013 7:09 pm
yup all mx-5's have an alloy bonnet, soft top nc's have an alloy boot as well ive heard,
alloy bonnet comes up nice with a polish
sailaholic
Postby sailaholic » Fri Oct 18, 2013 7:48 am
eunos90 wrote:Hi mxers I have an imported 1990 NA Eunos Roadster. Both bonnett and boot are standard aluminium. Thay certainly did things a bit different with their home market. Cheers Mike
Are you really really sure? Was there anything non standard on the car when it got imported?
wassup
Postby wassup » Fri Oct 18, 2013 9:48 am
My thoughts too. The 1028 seems to be the only NA that got a factory aluminum boot. Easy enough to confirm. It should only weigh 3.5 kg
1990 NA6
Civic Type R
Postby 93_Clubman » Fri Oct 18, 2013 9:58 am
eunos90 wrote:I have an imported 1990 NA Eunos Roadster. Both bonnett and boot are standard aluminium.
A number of people have thought that as it did get wrongly mentioned on various MX5 forums, but it's not usually the case.
Jash
Postby Jash » Fri Oct 18, 2013 10:41 am
Alloy Bonnet, Steel Boot on mine. Man I love that M2 Boot, but for 1500 bucks for a secondhandy I reckon I'd go carbon and pocket the difference.
