Air Conditioning Compressor
Posted: Wed Oct 09, 2013 11:23 am
by NitroDann
Did they change it at all during the NB series?
NB8a and NB8c will swap without problems?
Re: Air Conditioning Compressor
Posted: Wed Oct 09, 2013 11:57 am
by 16bit
i believe on nb8a's they were an aftermarket item fitted by mazda australia.
not sure if its a direct swap?
Posted: Wed Oct 09, 2013 12:00 pm
by NitroDann
Thankyou, just trying to find out for a friend who needs a new one, and is looking at a good used one from an 8c.
Posted: Wed Oct 09, 2013 12:07 pm
by hks_kansei
As 16bit said, NB8A were all dealer fitment, but I beleive they were an actual Mazda unit, rather than an aftermarket.
Posted: Wed Oct 09, 2013 12:13 pm
by david_syd_au
I have the air-con out of a JDM NB8A, which I presume was factory fitted, and would be interested to know if it is likely to differ from the dealer fitted system in Aust delivered cars.
Anyone know?
Posted: Wed Oct 09, 2013 12:20 pm
by hks_kansei
david_syd_au wrote:I have the air-con out of a JDM NB8A, which I presume was factory fitted, and would be interested to know if it is likely to differ from the dealer fitted system in Aust delivered cars.
Anyone know?
I'm pretty sure they are the same.
If I remember correctly I think it was more to do with shipping (something about Japan using gas that wasn't allowed in Aust?)
edit:
http://www.mx5cartalk.com/forum/viewtop ... 1&start=15
Posted: Wed Oct 09, 2013 1:20 pm
by david_syd_au
[quote="hks_kansei"I'm pretty sure they are the same.
edit:
viewtopic.php?f=18&t=35311&start=15[/quote]
Thanks
So Mazda Aus imported MX-5s without air-con to avoid a "luxury" tax!
Sounds funny now :-)
Posted: Thu Oct 10, 2013 6:50 am
by Boyracer
Most MX5's had the A/C as genuine option, all the ones installed in Australia should be the same but some came from Japan with A/C installed, the Jap version is different, if you look at the firewall where the pipes go through the Aussie version has 2 pipes, the Jap. Version has an alloy block in the firewall, the compressors are different.
