Sigh... 1.6L crank problems...UPDATED 22/7
- JSE
Option 1
Replace crank and crankshaft and fix problem - approx $1300
Option 2
Replace 1600 with another 1600 engine - approx $1600
Option 3
Replace 1600 with 1800 - approx $2400
What do u guys think? My crank is stuffed! Being realistic and considering I am a full time student, what do you guys think would be the best and most suitable/appropriate option?
Option 2
Option 3
- bigdog
- King of the kennel
- StanTheMan
tough question. I'd do a 1.8 next time aroundbut I'm not a student. but manage to still have less money than you LOL. (tragic...isn't it?)
loctite fix. if you do it yourself, should be a hole lot cheaper than that.
its just labour intensive. Plenty of instuctions on the big forum. Being a student ....should make that a breeze for you
quiestion beggs. how many k's have you got?
did someone replace the timing belt recently?
- rodent
- 강남 스타일
- kitkat
- Boyracer
- MX-5 Encyclopedia
- kitkat
Yoshi wrote:Dam thats bad luck dude.Probably go for a long nose 1.6 swap if i were you. How many klms? What happaned? Im a paranoid short nose crank owner.
if your paranoid and want to put your mind at ease why not do a timing belt/waterpump/crank pulley/woodruff key/crank seal change? that way you can inspect it all and if the key way is begining to wear away you can get to it with loctite before the problem becomes major.
kitkat wrote:Yoshi wrote:Dam thats bad luck dude.Probably go for a long nose 1.6 swap if i were you. How many klms? What happaned? Im a paranoid short nose crank owner.
How much do you think that would cost? The reason why i ask is, i was thinking of getting my 130,000km service done as its coming up soon. I would want to do the servicing myself after that, but just wanted to get the car check out by someone that knows the mx5, to see if anything is up with it, as i have only had it for about a month, , and like you said to get the crank checked out. I have read if not done right that it could make the problem even worse, so my other question is anyone know someone is syd that knows the mx5 quiet well. Thanks. And sorry about the thread hijack.
1990 NA6
- kitkat
- JSE
I recently had the timing belt replaced ( and almost everything else replaced in one big hit) and thats when my trusted mechanic buggered it the bastard! I didn't realise and drove with it for about 4 months with it whinging and screaming and grinding when i turned the wheel (i thought it was the Poer steering pump busted) and now he won't refund me etc.
The crank was already buggered and butchered by the dude doing a homejob repair in Japan. And so it has been pissing oil ever since i got it and is unfixable.
However...the pickle of a situation im in is two... either convert it to a 1800 and eventually turbocharge it later on, or just fix the crank and sell it to upgrade to an NB in a few years (1 or 2 yrs).
I am pretty mechanically illiterate and wouldn't attempt to fix it or convert the engine myself and so those prices are for the engines and labour all included from MX5 Mania.
The current engine has 91,XXX on the clock...
It's such a hard decision with the wage I'm on only working casually!!!
- Craig
- Vehicle: Non MX-5
JSE,
Mate your in Sydney for crying out loud, home of \"Free Beer = Helpfull Hands!\"
(In more ways than one but that's usually on a Saturday night!
) Look...just get another 1.6, hire an engine stand/lifter/hoist and whack on a case of good beer and the spanner wheilding beer guzzling vultures will show up...simple as that!
*paging STM!*
Craig
Craig
*** Audi Q5 55 Sportback - HYBRID! Zero -100 in 5.3 seconds!
