13b renesis conversions available soon
Thanks for the info. any updates on the show if any would be great!
Thanks.
Thanks.
Re: 13b renesis conversions available soon
Just thought I will add some updated pictures....
- Old Dude
Nice job
cheers
Dale
cheers
Dale
MX 5 2001 Grace Green
NB8B
NB8B
- RawSouth
Impressive, looks like its supposed to be in there!
ロードスター
- Benny
Looking at the pics, it looks as though there is enough room for a second engine!
Maybe even a 4 rotor?
mmmm 4 rotor !
Why not just spend about $25k and buy a used RX8?
I am sure you can pick one up for less than the cost of a conversion + NA/NB donor car.
Regardless of whether I would do this myself, thanks for posting up the end result and for doing the conversion.
Hopefully it works out for you on the business side.
- orx626
- Vehicle: NC - Rotary
Rxticle wrote:handles better!
Disagree on this one...you have my support on the rest!
Rxticle wrote:Saw this in the metal today. Sensational work Tony.
Thanks and Good to know that you like it!
Are you thinking of going in this direction?
Is your mate Tony Stacey????? convicted Rotorphile... Arana Hills lad... Worked at Mazspeed virginia back in the day?? Had a big shunt in an RX4 once upon a time???
Apart from Mazda............ trust nothing else...
- orx626
lukearama wrote:Is your mate Tony Stacey????? convicted Rotorphile... Arana Hills lad... Worked at Mazspeed virginia back in the day?? Had a big shunt in an RX4 once upon a time???
That would be the same man.
orx626 wrote:lukearama wrote:Is your mate Tony Stacey????? convicted Rotorphile... Arana Hills lad... Worked at Mazspeed virginia back in the day?? Had a big shunt in an RX4 once upon a time???
You have recalled the past "lukearama", that was a long time ago!. what is your real name and how do you know me ????
Dan, you are quick on the replies but thats ok!. ( It will probably be Easter time before I reply otherwise!
Looks like you have everything happening at your new shop! And I like all your new toys (cars)!
I may see you on Sunday at the show if I get the chance!
My Renesis (RX8) / Rotary Engined NB MX5 (Miata) is now regretfully up for sale...
You can view it in the cars for sale section.
Thanks.
Thanks.
Hey, do you have any pictures of how you mounted the engine and gearbox? At least from the NA conversions I have seen most have chopped up the stock subframe pretty extensively and used a modified oil pan but it looks like you may have been able to fit it in with engine mounts alone. I take it the NB has a taller transmission tunnel? Your swap looks really clean.
