- NitroDann
First time I ever saw your car Dave.
Wheres the fitment?
Wheres the fitment?
Still can't decide which wheels I want / can afford.
Just did low headlight mod with rectangle headlights as the popups were so annoying in the hills. Went for a run last night and i could actually see the roads for once. Also put front and centre underbody bracing which made a big difference over the small bumps. Lastly installed revlimiter gauges in which look old school but classy.
- NitroDann
NitroDann wrote:First time I ever saw your car Dave.
Wheres the fitment?
Id have thought you knew me well enough to realise that the 'fitment' comment was sarcastic.
I think it looks good.
- Uncle Arthur
- Dodgy Award Benefactor
- Location: Doesn't matter where I'm from-it's that your daughter is with me that's the biggest concern :D
Well over the weekend I:
replaced the front brake pads
fixed the intermittent window switches
fixed the stuck centre console cubby hole lock
lamented the fact that I still have to get the dents fixed from the cement truck that hit the car while parked.
- Smacca
Installed a new head unit and splits.
Smacca | 1993 NA8 Clubman
- taminga16
Installed a beautiful girl into the other seat and went for lunch.
Greg.
As odd as it may sound there are people here that will truly appreciate the significance of this.
Greg.
- Uncle Arthur
taminga16 wrote:Installed a beautiful girl into the other seat and went for lunch.
Greg.
You had a BOV fitted?
- xhonda_boy
Car wouldn't start yesterday afternoon when I went to crank it. Just keeps clicking over.
SO I left the car at work and came back today.
Pull out the fuel pump and gave it a good shake and now it starts.
** New fuel pump is on the cards **
xhonda_boy wrote:Car wouldn't start yesterday afternoon when I went to crank it. Just keeps clicking over.
Hey John, had the same problem last year - if you haven't already, while you're at check the fuel pump in-tank wiring harness for 'black wire': viewtopic.php?f=55&t=46425
- xhonda_boy
93_Clubman wrote:xhonda_boy wrote:Car wouldn't start yesterday afternoon when I went to crank it. Just keeps clicking over.
Hey Paul,
I might have to check the wiring as you mentioned, As I just put in a new fuel pump + new fuel filter and still keeps cranking like before.
Cheers.
Well today I finished replacing bushes on one corner - three to go. Not what I'd call a hard DIY but boy it sure takes time! Used Blacktop chassis paint to finish off and it seems a great product. Goes on with very few brushmarks and supposed to be tough.
NB SE, NA 1.8.
- Kev05
Carelessly etched a 10cm scratch mark along the boot whilst removing the hardtop tonight. Oh well, sh*t happens.
- Jeo
Realised the headlights won't pop up if you don't have the button on the dash connected. Solution - drive home with just the parkers on?
Users browsing this forum: No registered users and 29 guests
