greenMachine
Postby greenMachine » Wed Apr 24, 2024 8:10 pm
I'll do more of a writeup for my build thread, but the Powertune dash installation is progressing nicely. The double-DIN blanking plate is cut, and just need some washers to mount and install the dash in the centre console.
The next trick will be to program it, it is already connected to the Link and the default display is working. I need to find a good block of time (maybe mote than one :wink: ) to build the display I want, I need to find more time to re-install the oil cooler, remote filter and connect the oil pressure/temperature sensors to the auxiliary harness, install a coolant pressor sensor (probably just a binary (warning light) one not a real gauge sensor. The installation of that will happen at the same time as the ditching of the pretend oil cooler (warmer?) the factory fitted.
:mrgreen:
