rob_hun7
Postby rob_hun7 » Wed Oct 02, 2019 4:47 pm
I just finished putting my car back together after painting my valve cover and doing some tidying up. I used Duplicolor Metalcast paint. I think it looks alright. It looks kinda like a blood red :NB8B:
LiteIsRite
Postby LiteIsRite » Wed Oct 02, 2019 10:46 pm
^^ I can appreciate that ^^. Well done!
"Cherry" - Classic Red 1990 NA6 :NA6: [sold]
legume
Postby legume » Thu Oct 03, 2019 1:59 pm
Chuppa wrote:Adjusted the clutch friction point, de-leafed the fenders, de-oiled the engine bay.
Even though the MX is small, it is suprising that it is not so uncomfortable to be upside down under the dash.
On a recent manual conversion to the family car (Legnum), I spent considerable time upside down under the dash. Now that was uncomfortable. I had also tweaked my back moving the trans. It took me a quite a few minutes and a large amount of swearing to get out from a painful position.
I find it so much easier with the top off.
Postby 93_Clubman » Fri Oct 04, 2019 8:23 am
legume wrote:I find it so much easier with the top off.
Removing the seat also makes it much more comfortable.
Gladiator
Postby Gladiator » Tue Oct 08, 2019 1:09 pm
I finally got my bikini top sorted. I bought it off a member interstate a few years ago, & due to a communication error re type of roll bar, it didn’t fit my car, so it went into the too hard basket.
Now that it’s done I’m kicking myself. It only took an afternoons work & $85 at the upholsterer.
ManiacLachy
Engaged
Postby ManiacLachy » Tue Oct 08, 2019 1:39 pm
That's excellent. A bikini top is on my want list! I'm sure it's on lots of people's want lists :mrgreen:
My zip down window provides the same air flow effect, but doesn't look nearly as cool!
MX5NBpsi
Postby MX5NBpsi » Wed Oct 09, 2019 9:43 am
Got my manifold in and moded for the bosch throttle
:NB8B: [SLOMX5]
Postby bruce » Wed Oct 09, 2019 3:17 pm
That's one of them new turbo setups where boost gets to the engine via ESP!
Postby Magpie » Thu Oct 10, 2019 10:32 pm
Remove 5kg of QR gravel from the car...
StanTheMan
Postby StanTheMan » Fri Oct 11, 2019 1:44 pm
I smashed my Cam sprockets
car spat them out. Bitch of a thing. broke the cover & all
Feenix spat the dummy
that's not the only toasty bit
the bolts dameged the other cam sprocket, crank sprocket & new belt were all toast.
Postby bruce » Fri Oct 11, 2019 2:14 pm
Jeebus!
ManiacLachy
Engaged
Postby ManiacLachy » Fri Oct 11, 2019 2:36 pm
Oof, that's not what you want to see!
Chuppa
Postby Chuppa » Fri Oct 11, 2019 8:56 pm
Wowsers! How do you think happened?
‎"We are all self-made. But only the successful will admit it."
StanTheMan
Postby StanTheMan » Tue Oct 15, 2019 12:16 pm
Chuppa wrote:Wowsers! How do you think happened?
bolts not tight enough, but instead of bolts flying out, the sprocket should just have gone to max retard.....the bolts should have stayed in no matter what. We fixed it all up. New belt, new crank sprocket filede down sharp edges on the cam sprocket. New bolts. new washers. all nice & tight. the next day on the test drive the other side does the same.
I replaced the intake one totally. With an OEM one. it was beyond repairing. I drove around with a allen key to insure exit Cam sprocket wasn't coming loose again. I also left all the covers off in-case a bolt comes out & flies away rather than flying around inside covers causing damage to the belt & spockets.
StanTheMan
Postby StanTheMan » Tue Oct 15, 2019 12:55 pm
Broken down after after inlet Cam gear becomes toast
Fixing exit Camgear, new bolts , re-thread , new washers.
We filed off & smoothed out the teeth on this cam-gear to spare the cam belt.
this cam gear totally blew up & it was retired to the dust bin. Replaced with a non adjustable OEM inlet cam gear
