3gress
Postby 3gress » Sun May 12, 2019 8:40 pm
My view is the new brake setup feels superior to the stock setup with a comfortably firm progressive pedal application that allows more precise control. The raised mounting point of master and pushrod position helps to keep the pedal force manageable whilst allowing fine modulation especially helpful with heel-toe rev matching and trail braking.
I often apply a little brake while coasting downhill and use the same rigjt foot to apply just enough throttle to limit the pops and crackles from exhaust and this is considerably easier now with the firmer pedal.
I used a 7/8" ba astina master cylinder due to its brake line port design and shorter length than other Mazda masters. It shares the same design as early nb masters where a larger diameter rear extension with o ring seal fits into the booster and has the extended pushrod mounting tube.
Nb, ba astina (97 4cyl, non abs), na6 masters left to right respectively.
Boosters for the different models.
I have numerous master mount plates available as the lazer cutters required minimum order amounts of ten.
The bore size suits the nb style master rear diameter however the smaller rear diameter of na6 master will fit with room to spare.
I am running NA8 front brakes with bendix road pads and NA6 rear rotor and pad sizes for the moment with wilwood proportioning valve adjusted to suit. A move to larger rear rotors is being considered to compare performance if not only because they are on hand in my shed to fit.
I used an old transmission bellhousing bolt to fab a new pushrod, cutting the head off and rounding the end on a drill press with files. A small bush approximately 15mm long and turned to a tight fitting diameter was first installed within the rear master pushrod tube receptacle to prevent the pushrod fouling when swinging through it's arc between pedal limits. There is a possibility to raise the pushrod- pedal mounting point higher than the 20mm increase as on my pedal arm that would reduce pedal effort further. Using a smaller 13/16" master is possible also.
Image the reservoirs between astina and mx5 master are interchangeable and the clutch master from the astina is a little more compact in design freeing up some room for throttle bodies as in my case. The astina reservoir provides a feed for the clutch master which is said to be beneficial to fluid circulation.
It all started with a purchase of a booster delete kit from chase bays that was frown upon by our Christmas holiday hosts and led to thorough research of a suitable design using factory components.
A big thankyou to those who provided their time in helping me with the design.
Overall very happy with the improvements to braking performance.
Postby hks_kansei » Sun May 26, 2019 4:23 pm
I got the exhaust welded up.
It will probably break again, since my midpipe etc is a jigsaw of bits and pieces, but at least now it's all going out the back where it's supposed to.
And now it doesn't sound like an old tractor.
Postby Regie » Mon May 27, 2019 8:19 pm
put it in the garage and purchased a new car
NC up for sale :D
StanTheMan
Postby StanTheMan » Mon May 27, 2019 8:25 pm
New chapter for Reggie.
White goods with a fancy letter. Prolly goes like a pig shot in the backside.
Congrats.
drckarcher
Postby drckarcher » Thu Jun 06, 2019 2:32 pm
Swapped the orange indicator bulbs on my NB8B to silver ones. It looks great but the new bulbs seem not to be as bright as the old ones. Is there a LED solution available?
Sent from my iPhone using Tapatalk Pro
Chuppa
Postby Chuppa » Sat Jun 15, 2019 8:04 pm
(NA6) Replaced the central locking actuators and fuse. Generic replacements from Jaycar did the trick.
Chuppa
‎"We are all self-made. But only the successful will admit it."
Postby Magpie » Mon Jun 17, 2019 12:20 pm
Dropped it off to have some 'stuff' installed
2 of these
To fix up some of this...
3gress
Postby 3gress » Mon Jun 17, 2019 12:34 pm
Dang, for a second there i thought that was the finished product!!
Keen to see engine loom finished if it's any thing like the engine loom pics I've seen from whiteys wiring.
When i did mine I cut as many plugs out as i could thinking it would eliminate problem areas. 'I don't need a firewall main plug' i thought, banking on the fact I'd not be removing the engine constantly....how wrong i was !! Only had it out 3 times in the last 6 months!
3gress
Postby 3gress » Mon Jul 01, 2019 10:51 am
Pre installing new maruha intake cam
With 1mm measurement shims...check the gap.. Image
Giving it all a good once over Image
NA6089
Postby NA6089 » Tue Jul 09, 2019 8:51 am
I've made a start on the Hard Top reno.
Sadly the paint under the rear window is total cr@p. Instead of a bit of a sand to prep for paint, it's needing paint stripper and scrapers. :-S
Greg
Postby Magpie » Tue Jul 09, 2019 3:37 pm
Organised something like this to be done whilst getting rewired...
Postby bruce » Tue Jul 09, 2019 3:49 pm
Nooooo, Magpie is a closet Ricer!
Postby Magpie » Tue Jul 09, 2019 10:30 pm
bruce wrote:Nooooo, Magpie is a closet Ricer!
If I cannot be fast I may as well start looking like I'm fast....
ManiacLachy
Engaged
Postby ManiacLachy » Wed Jul 10, 2019 7:40 am
And furious :mrgreen:
Red_Bullet
Vehicle: NA8 - Supercharged
Postby Red_Bullet » Wed Jul 10, 2019 10:03 am
Put some Flow force 640 injectors in it that I got from Beavis. (Fast service by the way) Fiddling with VE table again, all good fun.
