Info / advice on registering a modded MX5 in Victoria
Re: Info / advice on registering a modded MX5 in Victoria
Postby 93_Clubman » Wed Nov 29, 2017 11:14 am
Great result, but yeah you've got to ensure all are eyes dotted & tees are crossed!
RileyR wrote:viv certificate numbers (Victorias equivalent of modplate I am assuming).
'Vehicle Identity Validation (VIV) inspection:
VicRoads may accept an interstate written-off vehicle inspection. However, it reserves the right to require a vehicle entered on the Written off Vehicle Register (WOVR), including specific interstate vehicles classified as inspected write-offs, to undergo a VIV inspection to ensure that the vehicle is correctly identified and repaired appropriately'.
https://www.vicroads.vic.gov.au/registr ... inspection
VASS approval certificate is equivalent of QLD mod plate:
https://www.vicroads.vic.gov.au/registr ... ertificate
Postby KevGoat » Wed Nov 29, 2017 12:14 pm
Different regulations state to state are ridiculous, they should be National. Same with road rules.
RileyR
Postby RileyR » Wed Nov 29, 2017 6:55 pm
Yeah im stoked it all worked out!
Thanks everyone for the help and pointing me in the right direction! I might be seeing some of you around the traps. Ill look into the victorian club and also see what motorsport I can get involved in.
And yes I certainly think there needs to be a national standard. Hopefully it wouldnt follow NSW's lead though...
Sent from my SM-G900I using Tapatalk
1996 BRG NA8
Postby hks_kansei » Wed Nov 29, 2017 11:05 pm
Club wise, really depends what you're into.
I found the Vic mx club to be too much money for stuff I never used, but if you're into cruises it's probably a good option.
If you just want a cams licence or club rego, there are far better value clubs to join.
RileyR
Postby RileyR » Wed Nov 29, 2017 11:23 pm
Ok thanks hks, im not much into cruises so might give it a miss.
I would like to get involved in some sprints or time attack type things. Im not sure how much time I will get in the next few months though. Will have to play it by ear a bit.
1996 BRG NA8
