Purecaboos
Postby Purecaboos » Mon Nov 20, 2017 8:09 pm
Did my first mods today, removed the stupid sub visors. I fold mine open when I drive so I can see ahead and ended up smacking myself in the eye socket by accident.
Next was installing the CG-locks on the seat belts. Was almost late to get the tyres put on the patrol I was having so much fun. :-)
Greg
lucmor444
Postby lucmor444 » Sat Dec 02, 2017 7:02 pm
Installed my Project G quarter windows and did the maintenance (eg new window bushes, cleaned and regreased window tracks etc) on power windows so they are running smoothly and quickly now.
Perthpom50
Postby Perthpom50 » Thu Dec 07, 2017 9:45 pm
Picked it up from the shippers.
Reinforced why I bought it, what fun.
Should have been more thorough checking it though cos the drivers window which was down wont go up and there is a small tear in the roof which wasn't there when I shipped it. I am planning on changing the soft top for the one I bought for the NA though so no real drama.
Postby Okibi » Fri Dec 08, 2017 5:07 am
Beautiful! :mrgreen:
Postby 93_Clubman » Sat Dec 09, 2017 9:59 am
Perthpom50 wrote:Picked it up from the shippers.
Great to hear you've finally taken delivery of the SP - quite a journey.
Perthpom50
Postby Perthpom50 » Sun Dec 10, 2017 2:25 am
Pulled the drivers door spart last night and found a broken pulley on the slide with cables attached.
Window is very stiff mostly fromthe old grease I think.
Ive ordered a new slide from the us which should be here before the end of the year. In the mean time I should just be grateful that the window is stiff enough to stay up on its own so I can drive it.
Any suggestions on how to make it work or get a substitute for the broken pulley will of course be gratefully accepted.
Nick
Gladiator
Postby Gladiator » Sun Dec 10, 2017 9:16 am
I’m not sure if it’s what you’re after, but check out the post from Rolley on window guide bushes.
Postby 93_Clubman » Sun Dec 10, 2017 10:57 am
Often one of the ends of the metal cable pull-off causing the window to not stay up. Happened to both sides of my old NA6, but pulleys were ok, so removed broken cable & jammed window in up position until I installed a new cable.
Rolley's NA/NB Window Guide Bushes thread:
viewtopic.php?f=76&t=72566
Rolley's Window Guide Replacment thread:
viewtopic.php?f=44&t=72199
Perthpom50
Postby Perthpom50 » Sun Dec 10, 2017 2:47 pm
Rather than take over this thread I'll post a separate picture of the offending broken piece in the body work section. Can keep you posted as it gets fixed.
Nick
Postby Magpie » Sun Dec 10, 2017 8:02 pm
Made some new vortex generators
New rear pads - previous set was installed on 23/07. Since then have done quite a few laps on various tracks, including WTAC and few general practices on the National. These tracks are very hard on the brakes. I'm more than happy with how long they last and rotor wear.
Rotor wear
RL 0.65 RR 0.63
Pad wear (combined. a new set of pads is about 24mm)
RL 10.76 RR 10.40
Did an oil change
Remove more 'stuff' from the rear, including difusser...
Postby bruce » Sun Dec 10, 2017 8:05 pm
Go on, scare me with cost of the Unicorn Oil you used?
mrpham
Postby mrpham » Sun Dec 10, 2017 8:14 pm
Heel plate went in today =) Image
Current Forum Specials!
Postby Magpie » Sun Dec 10, 2017 8:16 pm
bruce wrote:Go on, scare me with cost of the Unicorn Oil you used?
https://www.takumi-motoroil.com.au they will be bringing in the 0-40 soon.
https://www.facebook.com/takumioilaus/posts/891938467631338:0
speed
Re: RE: Re: What have you done today/recently to your 5?
Postby speed » Sun Dec 10, 2017 8:20 pm
Magpie wrote:Made some new vortex generators
Careful Mark, these won't just improve your lap times but may very well put you in another dimension
Postby Magpie » Sun Dec 10, 2017 8:30 pm
Need boost to do that... will find out Thursday PM. Will also be running 225/45/15’s as well. Need to weight the car soon and set a new baseline. Have taken a bit of weight out of the rear recently.
New wing design now requires the front downforce to be reconsidered, so plans for that are in the pipeline. It will never end...
Users browsing this forum: No registered users and 27 guests
