2002 NB MX5 SP Tare Weight - Urgent please help
Engineer
Vehicle: NB - V8
Re: 2002 NB MX5 SP Tare Weight - Urgent please help
Postby Engineer » Sun Jun 18, 2017 12:46 am
Hi,
Thanks Locutus...I had feared that Mazda did not update the tare weight from the std car even though the car should technically weigh more. The SE is rates at 1093kg as stated above...The SP has to be at least that...the official tare is likely inaccurate. Obviously Mazda thought that no one would care... except...well me :)
Thank you for clarifying...and now I have a seriously uphill battle on my hands with the compliance submission.
Thanks to all for the support! :)
Postby NitroDann » Sun Jun 18, 2017 9:59 am
Engineer wrote:
I cant just weigh the car and use that weight. I need the tare that was used to comply the car via it's approval number on the compliance plate.
I have no idea why that would be. I've engineered 30 odd cars, always used a weigh bridge and submitted the signed test paperwork.
Postby 93_Clubman » Sun Jun 18, 2017 11:20 am
okibi the forum owner put this together with input from forumites a few years ago: http://www.mx5cartalk.com/SP_SE_Comparison/
Notice that SP kerb weight of 1119kg seems not to include AC, hence kerb weight including AC is quoted as 1167kg - might be worth PMing okibi to see where he obtained this figure as it doesn't seem to appear in the SP SE Comparison input/construction thread: https://mx5cartalk.com/forum/viewtopic.php?f=81&t=57730
Google site search of mx5cartalk only found those weight figures in the SP SE Comparison thread, so they don't seem to have come from this site recently.
Postby bruce » Sun Jun 18, 2017 11:35 am
No point arguing as u said Mazda did not update weight from a std NB.
Why they did not do it? Probably because it made no material difference. It was not worth the paperwork to up it by a fraction.
Postby Mr Morlock » Sun Jun 18, 2017 11:39 am
I am going with Dan - proper advice from a practitioner. A ticket from the weigh bridge is proof not hearsay.
Postby bruce » Sun Jun 18, 2017 2:14 pm
He doesn't have an SP to weigh.
Plus, weights will vary due to amount of fuel and a lot have a roll bar nowadays. Up to if his engineer will accept a weight from a car which he has never seen (unlikely).
Postby NitroDann » Sun Jun 18, 2017 4:17 pm
He has his own conversion to weigh.
Engineer
Vehicle: NB - V8
Postby Engineer » Sun Jun 18, 2017 4:47 pm
@NitroDann
Thank you so much for the input. Could you kindly elaborate on that weigh bridge experience. I am keen to hear which engineer you used that would accept a weigh bridge reading. This is encouraging as it may be an option. I hope I was ill advised and they will indeed accept a weigh bridge reading.
As you have gone through this on multiple occasions it would be awesome if you could be kind enough to share your experience and recommend how it could be done. I am based in Sydney if that helps as different states may treat things differently.
Thanks NitroDann much appreciated ....
I will pm okibi to see if he can shed some light on the kerb weight story!!
Postby NitroDann » Sun Jun 18, 2017 6:05 pm
You're free to use an RMS approved weigh bridge and just submit an official weight certificate to the arms for an updated curb weight.
legume
Postby legume » Sun Jun 18, 2017 7:49 pm
Im intruiged how a weighbridge weight is sufficient.
VSB 14 LA states"
2.13.1 Vehicle Mass
The mass of the vehicle referred to in Tables LA1, LA2 and LA3 is the original (unmodified) tare mass of the model vehicle fitted with the largest engine available for the model in Australia but without optional accessories (air conditioning, tow bars etc.). The mass of the vehicle, whether it is a sedan, station wagon, utility, etc., should be based on the heaviest sedan version of the model (not station wagon version) sold in Australia. "
Also noting conversions for cars under 800kg the max capacity is 3x mass and 2.5 for forced. 800-1100 is 4x mass and 2.75 for forced. 1100 and over 5x mass and 3x for forced.
Hence the problem Engineer is facing. for a 5.0 it has to be over 1100kg. I would quess that as the max for a turbo on an NB would be approx 1060x 2.75= 2.915, that the engineer would not be to fussed about a weighbridge figure as he is safe by quite a margin.
If you want a V8 then the few choices are Lexus, Nissan Vh41 or a Rover v8 (last of the Rover powered Land Rover, for engine age requirements)
VSB14 LA https://infrastructure.gov.au/roads/veh ... 011_v3.pdf
VSB14 https://infrastructure.gov.au/roads/veh ... _ncop.aspx
Postby bruce » Sun Jun 18, 2017 9:38 pm
I agree with Legume. It's all there in writing.
My Vic Engineer concurs and would not approve a 5.0 litre.
Engineer
Vehicle: NB - V8
Postby Engineer » Mon Jun 19, 2017 12:16 am
Hi All,
Again thanks fro the great input!
Yes I have read and re read Vsb 14 many times. Regrettably that standard that relates to engine vs weight was written by a team of bureaucrats with little to no understanding of the laws of physics. As such the arbitrary ratios selected for the engine to weight "formulas" in section 2.13 in that vsb 14 standard are baseless and do not comply to any level of sound reasoning, good engineering or scientific standards in general,. They were arbitrarily selected "thresholds" plucked from thin air and then reverse engineered to produce the ever so convenient (and nicely rounded would you not say ?) 3 x, 4x and 5 x ratios vs the tare kg weight. It so poor in what it tries to achieve, so poor.
It cannot be reasoned by any law of physics that the dynamics of the vehicle in question will experience "step function" changes in its behaviour at the magic 1100kg mark. Could it be proven for example by the RMS crack team of "scientists" that a 1093kg car (current official RMS verified max tare weight of an NB MX5 which is the SE model) is incapable of running anything larger than a 4.3L engine whereas an 1100kg car can safely run a 5.5L ? Do they have the physics to prove this ?
Does that make sense to anyone who has any idea how physics and vehicle engineering actually work ? I say no, as this part of the vsb is so poorly contrived that it insults our intelligence.
So let me run that another way..
The RMS is telling me that a 7kg increase in tare weight (from 1093kg to 1100kg) means that a 25% increase in engine capacity is permitted? By what laws of physics did the RMS decide that 4.3L is OK at 1093kg but a 5.0L is not safe..but add 7 kgs and your car is now safe to run 5.5L..WTF ?
If the RMS had any idea at all they would leave "step function" changes alone and use a linear scale for engine capacity vs tare weight. So with every kg increase in tare weight the engine size would increase in proportion. I would be happy to pen a basic algorithm (as would anyone else with year 6 maths skills) for them to use to do just that.
It would simply ask for the tare weight and give you the maximum engine size, every kg change moves you either higher or lower on the engine capacity scale. That is the only way to do it so its correct and in line with sound practice, anything else is gonzo engineering.
The other way is to use power/weight ratio as the determining factor for vehicle safety and drop capacity to kg completely as the measuring stick.
If I had the money I would take the RMS to court and challenge the pathetic vsb 14 section 2.13 on the basis that it is inconsistent with any law of engineering and science in the way that it defines its thresholds or boundaries for engine capacity vs weight. There is no magical event that occurs at 1100kg of tare weight, not a single thing, zippo, nada.
I could potentially challenge the RMS, as the vsb stipulates what the Maximum Recommended Sizes are. These are defined as recommendations or guidelines and not absolutes in the way the vsb language reads.
I could argue that being off the "magical" 1100kg mark by 7kg at 1093kg (or by 0.7%!!!) warrants consideration for a 5.0l. If the standard is indeed stating that at 1100kg the "recommended" maximum is 5.5L then I do not see how unreasonable a 5.0L is at 1093kg. The car is within 0.7% of the recommended tare weight and 10% UNDER the maximum recommended engine size. Only 0.7% off the target weight BUT 10% UNDER on maximum engine size for that 1100kg target weight.
A case for reason?
Sure, if you lived in the real world....the RMS doesn't live there.
So hence I am sitting on a knife edge with only 7kg separating me from finishing my car and satisfying the pathetically rudimentary and ill reasoned legislation as is.
So I am here, hoping to get a different tare weight from Mazda for the SP so I trip over 1100kg on tare wight and build my car. From everything I know the SP is definitely heavier and must be over 1100kg on tare weight, maybe 1119kg as stated by someone in a previous post. But I don't have that yet on official record...and I need it to build my car without issue.
The alternative is a legal challenge and although I can easily prove that section 2.13 is erroneous on any level of scientific reasoning, I regrettably don't have the depth of pocket to feed the lawyers to work it with me.
But as this has been a running issue with me for a quite a number of years, I would not mind having a crack just for giggles. Imagine the scene as the RMS scientists try to explain the scientific reasoning for why 1100kg was selected as the very important threshold and not any other numerical value of the tare weight.
Grab a bag of popcorn for that one..LOL!
I will keep everyone posted on my progress.
@Bruce: Cheers for the response. I agree and I understand that your Vic Engineer would not approve a 5.0L on the legislation as stated, but any engineer worth a dime would/should have the sense (and balls) to reason against this standard using data and sound scientific methods, because it is nonsensical as it stands today. Engineers are paid and qualified to assess each case on its merits and the legislation should provide the structure to let them do it, otherwise the authorising engineers are doing little "engineering" and more "administration".
@Legume: Faced between the choice of Lexus V8, Nissan V8 or Rover v8...I choose the 1.8L Turbo option. Those V8's are anemic and don't warrant the effort to install. :)
Thanks so much to everyone for their comments and assistance. As is clear from my language above, Section 2.13 from vsb 14 is a sore point for me because it makes no scientific sense and as a result of its absurdities I cant build my car.
Will keep pressing on with it...hopefully this week will bring it in.
Cheers All!
Postby Okibi » Mon Jun 19, 2017 1:02 am
93_Clubman wrote:... might be worth PMing okibi to see where he obtained this figure ..
I can't remember i'll try and find the original brochure, I have a copy of the Wheels Feb 2002 comparison with the S2000, it lists the SP as 1119kg.
Postby bruce » Mon Jun 19, 2017 10:13 am
You can build it if u do it as an ICV.
chops
Postby chops » Mon Jun 19, 2017 10:32 am
My NSW SP rego papers says 1093kg
Users browsing this forum: ManiacLachy and 5 guests
