If you buy the 949/Trackspeed one, it is plug and play (no reaming required).
If you buy from anyone else, you will need to specify the 85.5mm item. Most Cometic gaskets are made to fit a max 85mm bore and these ones will need to be reamed out. Deckspeed can source the 85.5mm gasket for you locally if you need it.
nb8b coolant reroute???
- zossy1
Re: nb8b coolant reroute???
zossy1 wrote:If you buy the 949/Trackspeed one, it is plug and play (no reaming required).
what would it cost me to get one supplied with the motor, i have a feeling if i order something ill make a ƒü¢k up and end up with a 83mm head gasket from a honda :')
