Regie wrote:When i ran 17x8 wheels i had 215-45's on them. They fitted quite nicely
Yep but if you were going to buy a set of 8" rims and your old tyres were shagged, you'd fit 225s.
Dan wrote:If it was me if buy wheels and tyres at the same time and avoid any compromise. If you want to run keep both sets you can buy the new set up and hold onto them while you run the stock ones down and if you want to sell the stock ones just sell them with tyres on.. Saves some cash in not having to swap tyres on rims too.
Charlie Brown wrote:I think most of your questions have been answered but I’ll summarised it for you starting from the front and going to the rear.
POWER
AEM CAI – not worth the money, possible increase in power on a good day 0.5kW, can lead to bent rods when the engine ingests water due to the low intake position. The NC has a stock CAI.
GWR header – the best bang for the buck modification for the NC. Will add about 10kW. No it’s not legal, it deletes the first cat. You need to add another O2 sensor bung after the second cat and extend the O2 cables to fit either side of this cat. To make legal you need to fit another (read ‘bigger’) cat in the midpipe, which given the room, may be a problem.
GWR mid pipe – If you don’t have the header you’d be hard pressed to notice any difference in performance.
GWR muffler – a legal modification, good sound for a small gain in output, maybe 2 – 3kW.
You didn’t enquire about a tune. More power is to be gained here especially if you install the header.
WHEELS & TYRES
The stock rim is 17x7. 205x45x17 tyres are the stock size but the rim width also supports 215x45x17 tyres which are cheaper to buy. You can’t go wrong with the Michelin PS3’s at around $180ea. The stock rim is too narrow for 225 section tyres.
Maximum legal width is 8” and to maintain a legal track width you need to have a minimum 43mm offset. Also you need light rims, which restricts you to just a few brands.
UNDERBODY BRACES
Save your money for something else. They are on par with CAI’s.
SUSPENSION
The cornering ability of a stock NC improves dramatically with a set of adjustable sway bars. Probably should be the first modification you make.
Shocks - Save, save, save for the best you can afford. Do not buy cheap coil overs. You are far better off with a set of lowering springs and quality adjustable shocks rather than $1100 coil overs, especially for a daily drive. Remember to stay legal the car has to have a minimum underbody clearance of 100mm. It starts at 119mm and as most of the aftermarket springs have a 35mm drop you can see you may run into problems straight away.
You should also remember that some of what you read on the US sites may not apply to us here in AU. Tyres (not tires), rim widths, power output, gear ratios, diff ratios, model year, etc are just some of the things that are different. We don’t have Mazdaspeed equipment here so it’s not considered a legal Mazda extra when fitted.
If you need to find out more, join the VIC MX-5 Club and have a chat to the boys there who have done it all before.
jassi wrote:^^ lets see. I hear super-q is around 15% louder than stock.
While I wait for my super-q to be delivered, I'm getting worried about the muffler flange and oem mid pipe flange not sealing well with gwr supplied flat gasket. There is a whole thread on it here http://forum.miata.net/vb/showthread.php?t=468164 Unsure if others with oem mid pipe and aftermarket mufflers had this issue!
I've made a point of reading the regs in regard to my car, mine's not legal, but at least I know what parts aren't legal
jassi wrote:I've made a point of reading the regs in regard to my car, mine's not legal, but at least I know what parts aren't legal
So is it recommended to keep the oem parts at home, so in case they tell you to come for a road worthiness inspection, you can just get the stock stuff back on
taminga16 wrote:Start with a good front/ rear alignment
Greg.
