Hi - Introducing a new Frankenstein project
reuby_tuesday
Re: Hi - Introducing a new Frankenstein project
Postby reuby_tuesday » Thu Aug 07, 2014 12:56 pm
Sailaholic
Thanks for that info.
So I'm looking for Mazda Astina covers then. BF or BG both had the same B6 motor in them right? Looking at the Wikipedia page either model should be fine.
http://en.wikipedia.org/wiki/Mazda_Familia
Ill go to another wrecker here in Perth and try again armed with this new information.
Thanks again
Dat-za Car Build
[url]http://www.datsun1000.com/TopicView.asp?TopicID=668&Page=1[/url
[url](https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)[/url]
TTT
Postby TTT » Thu Aug 07, 2014 1:55 pm
Mate that head/intake setup looks exactly like my 1987 Ford Laser TX3.
here is an example.
http://cdn.skylinesaustralia.com/forums ... 487252.jpg
It's a large image so I left it as a link rather than paste a massive pic in here.
edit
Or it's Mazda Familia (323) sister
http://goanna.cs.rmit.edu.au/~caspar/engine-small.jpg
reuby_tuesday
Postby reuby_tuesday » Thu Aug 07, 2014 5:10 pm
TTT
It certainly seems so, but it must be a very specific model/year as most of the pics I have found of the TX3 have a log style intake that points to the back of the motor not over the top, and the vast majority of them have the dizzy on the exhaust side of the head, unlike mine. Hmmm slightly oddball but a B6 head none the less.
Dat-za Car Build
sailaholic
Postby sailaholic » Thu Aug 07, 2014 5:40 pm
Dizzy on the exhaust side is a BP motor not a b6 ;).
The astina in the link above with the log manifold is also a BP. Looks the same doesn't it :D
Age will be the key here. Check the 323 model at 87 and that will be what your looking for. Probably the sports / big engine variant of the time.
sailaholic
Postby sailaholic » Thu Aug 07, 2014 5:42 pm
Both the above photos use a afm (as did the b6 1990-1993 mx5). The bp in the mx5 got an MAF meter instead. maf looks like a round tube rather the the odd shape of the AFM with the spring loaded door.
reuby_tuesday
Postby reuby_tuesday » Thu Aug 07, 2014 11:48 pm
Ive managed to pick up a B6 mx5 intake. That will have an AFM ?
Ill post up a pic if this when I can. Its up the shed now, and its too cold to walk the 500m to the shed and wait for the lights to fire up.
Ill ring some wreckers in Perth tomorrow and see if I can find anything.
Thanks for the help folks.
Dat-za Car Build
sailaholic
Postby sailaholic » Fri Aug 08, 2014 6:52 am
If it's a full intake it will have a afm (ie all the plastic piping and airbox)
Afm isn't really needed / not desired if your going turbo with a standalone computer though
TTT
Postby TTT » Fri Aug 08, 2014 9:58 am
reuby_tuesday wrote:TTT
Yeah there are 2 TX3 models.
Old - 1986 - 1990
These were the 1.6L B6 engine ones.
This is the motor that your head came from.
Car looks like this
Engine looks like this
New - 1990/91 - 1995
These were the 1.8L BP engine ones.
Car looks like this
Now. in the old version, both the TX3 and the mazda 323/familia GT had the same 1.6L motor.
When the later TX3 and Familia GTX models came out, the BP motor had the BRAND on the rocker covers basically..
Ford
Mazda
reuby_tuesday
Postby reuby_tuesday » Fri Aug 08, 2014 12:44 pm
TTT
Thanks for all the information. It clears up the fog a heap. The pictures really make it clear. The early Tx3 motor certainly looks like mine.
I have rung a wrecker in Perth today looking for the timing covers. Hopefully they don't want drug money for them.
Dat-za Car Build
project.r.racing
Postby project.r.racing » Fri Aug 08, 2014 6:34 pm
The engine in question is from a 87-89 BD 323 or KE Laser. They are rare as rare can be. Not many twim cams before 1990 found there way to Australia. I really would attempt to use something more readily available.
sailaholic
Postby sailaholic » Fri Aug 08, 2014 6:51 pm
What would be the advantage of a later (more available) head? Just being able to sell the existing one on for more then it would cost to buy say a mx5 head?
project.r.racing
Postby project.r.racing » Fri Aug 08, 2014 7:54 pm
i just re read the first post.
keep thermostat and coolent outlet location. much better designed than 90-97 mx5 version.
forget what i said about the engine. the heads are the same. i thought you were using the fwd intake. corrected after re read.
the timing belt covers are the same as the BP engines. find any BP engine from a 90-94 Ford Laser TX3 or Mazda Astina SP and pull off the covers. Otherwise search fordlaser.com or astinagt.com for parts.
reuby_tuesday
Postby reuby_tuesday » Mon Aug 11, 2014 10:21 am
project.r.racing wrote:The engine in question is from a 87-89 BD 323 or KE Laser. They are rare as rare can be. Not many twim cams before 1990 found there way to Australia. I really would attempt to use something more readily available.
The motor combo itself may be rare, but the B6 head (which is the bit I want) is not. Plenty of they about in wrecking yards, plus they Kia still used them in the Sephia up till about 1997. For my needs, as long its a B6 head, its good to go for me. The block, intake manifolds, exhaust manifolds etc are just mix and match till I find a setup that works. For example, I'm using an MX5 intake and aftermarket turbo exhaust manifold, with a Kia Sephia thermostat housing at the back. That's the joy of a project like this. Its the learning and exploring till it all works.
sailaholic wrote:What would be the advantage of a later (more available) head? Just being able to sell the existing one on for more then it would cost to buy say a mx5 head?
Your right. There isn't any real benefit. One of the advantages of using the B6 head is it low cost and availability, plus it fits, which I personally think is the most critical point.
Now I'm chasing the timing covers. who knows which specific car that that will come from.
Thanks for the input guys
Dat-za Car Build
sailaholic
Postby sailaholic » Mon Aug 11, 2014 11:09 am
Any of the tx3 lasers mentioned above along with the equivalent year 323. B6 and BP use the same cover apparently.
If you don't care about accessing adjustable cam wheels with out removing the cover you could also get the mx5 bp rocker cover and matching lower cam cover. (Mx5 valve cover extends over the top of the cam wheels. I believed the Kia does the same.
project.r.racing
Postby project.r.racing » Mon Aug 11, 2014 10:23 pm
i corrected myself about the head/intake.
the info you require is 3 posts up.
as for attempting to mix and match engine parts. have you thought about using a 97-98 laser/323 B6 head. solid lifters, higher lift, less duration. much better for chasing torque. dissy on exh cam. still got the normal water rear outlet, not stupid mx5 front one.
Users browsing this forum: No registered users and 41 guests
