Australian Delivered Eunos? and LSD question
Re: Australian Delivered Eunos? and LSD question
Postby hks_kansei » Mon Mar 03, 2014 10:09 pm
project.r.racing wrote:Even if it was a torsen in 94. Its 2014 now, so it ain't a LSD no more...
Torsens don't really wear anything like a clutch pack or Viscous.
Torsens operate via gears, by the time the gears have worn out enough to make an open diff you'll have also worn the crown wheel and pinion.
They do however wear the thrust washers, which means the pre-load drops right off (On Torsen 2 anyway, can't remember if T1 has the same system re: preload)
sailaholic
Postby sailaholic » Mon Mar 03, 2014 11:20 pm
I don't think the t1 had the same washers in it.
Postby hks_kansei » Mon Mar 03, 2014 11:35 pm
May not have.
I only had a brief look at a T1 centre, whereas I've poked around a T2 up close.
