Where is my 1994 NA8 Engine number?
sailaholic
Re: Where is my 1994 NA8 Engine number?
Postby sailaholic » Sat Mar 01, 2014 10:22 pm
Kitchen gear is a lot less likely to get blocked with rust than paper. If your going to use paper use wet and dry paper and dab in water frequently to keep it clear.
booki89
Postby booki89 » Sat Mar 01, 2014 10:24 pm
ended up using a bit of scotchbrite (scuffing pad) to remove most of it. Still very hard to get in there without removing alot of things, its just visible. Should be ok for the inspection I hope...
Guran
Vehicle: ND - 1.5
Postby Guran » Sun Mar 02, 2014 7:56 am
Stick a camera in there and take a photo. You can often see the numbers easier in the photo when you zoom in.
