Finding a new evaporator for NA6
Re: Finding a new evaporator for NA6
Postby 93_Clubman » Sun Jul 22, 2018 12:18 pm
93_Clubman wrote:Some Mazda part numbers: N007-61-J10; N001-61-J10; & NA75-61-520D
Paolo wrote:part number N007-61-J10 (genuine) is the one that I need
NA75-61-520D (genuine) is the part # used in the US, which isn't to say it's the same or a different evaporator (that remains to be seen), but it's obviously a different part #. I think N001-61-J10 is an earlier version of the other part #.
Paolo
Postby Paolo » Tue Aug 14, 2018 8:57 am
I ended up finding a used evaporator.
Within the NA6 model, there was a change in evaporator models too...which is a bit of a complication if buying used.
I will have it leak-tested....which will only tell part of the story. Apparently the evaporator is constantly under much greater pressure than a leak-test can show...so it could check out ok on the bench but fail when charged with refrigerant. Fingers crossed...
I was told that the evaporator fitted to Australian delivery MX-5s of this era were fitted with a locally made unit....and that 'local' company has since shut their doors.
Ahh...the perils of living to a twilight age...
Postby 93_Clubman » Tue Aug 14, 2018 11:08 am
Paolo wrote:was told that the evaporator fitted to Australian delivery MX-5s of this era were fitted with a locally made unit
IIRC, that's consistent with aka_juffa's research re ADM NA AC components generally. Did you source a local used evap or an OS one?
Paolo
Postby Paolo » Thu Aug 16, 2018 1:39 pm
It was a locally sourced item. Registration is due within the month so will ask mechanic to check it then.
Paolo
Postby Paolo » Fri May 03, 2019 3:57 pm
My partner's MX5 was with our mechanic yesterday. The used evaporator that I purchased last year was to be fitted.
Unfortunately, whilst the fittings are in the same position and look similar, the connectors were a slightly different size to the ones in the car. :cry:
A last-ditch 'solution' was to introduce a canister of an American product into the a/c system that is designed to stop leaks in car air conditioners (can't remember the name). It is in gaseous form and costs around $150.
There was cold air from the a/c this morning but time will tell if the system holds pressure.
If this doesn't work I am prepared to give in.
Postby 93_Clubman » Sat May 04, 2019 12:52 pm
Thanks for completing the loop with the update. Hopefully the latest fix continues to work.
SLO_NA
Postby SLO_NA » Sat May 04, 2019 9:47 pm
I can confirm that this part is no longer made (using Amayama) but since Mazda is phasing in their new restoration program they may start producing them again (they update the parts list every month): https://www.mazda.co.jp/carlife/classicmazda/parts/
I also managed to find the part number for the initial unit and the revised one including when the switch over happened:
N00161520 (until 1/08/1991)
N00761520 (from 1/08/1991)
However, the best option is to ring up the Mazda parts department and see if they can get it.
2005 MX-5 SE Turbo
2001 RX-7 Type RS
2002 RX-7 Spirit R Type B
2010 RX-8 S2 GT
2009 RX-8 S2 Luxury
2014 GT86
1996 MX-5 LE
1988 LN106 Hilux
Postby 93_Clubman » Sun May 05, 2019 12:16 pm
Thx also, useful to know.
Users browsing this forum: Google [Bot] and 6 guests
