missifire, need help
Zabinskii
Postby Zabinskii » Fri Jan 16, 2015 6:52 pm
hey,as the title says my car has a misfire, 1990 1.6 and when i heel toe the car does a slight dip in rpm and then rises, unless it is above 4,500 rpm or so, anyone know what could be causing this? cheers! :)
Re: missifire, need help
Postby Magpie » Fri Jan 16, 2015 7:13 pm
What technique are you using to heel/toe?
Zabinskii
Postby Zabinskii » Fri Jan 16, 2015 8:11 pm
http://www.drivingfast.net/car-control/ ... ifting.htm this is the one, didnt know there was more than one technique but this haha, and it does it with general rev matching aswell. lets say im coming to a roundabout or lights and i see they will be clear or green ill try rev matching but the revs feel like the drop then kick back in, starting to be more of an issue than when it first started happening, thinking coil pack is going replaced spark plugs after it started happening and nothing
Zabinskii
Postby Zabinskii » Fri Jan 16, 2015 8:13 pm
does it every time i tap the accelerator when releasing the clutch to take off aswell,
speed
Postby speed » Mon Jan 19, 2015 6:51 pm
Perfect reason to start flat changing :D
Gladiator
Postby Gladiator » Sat Jan 24, 2015 9:45 pm
I think I'll leave this one alone. Sorry.
