OBDII Codes
Sailor
OBDII Codes
Postby Sailor » Fri Apr 11, 2014 12:59 pm
I've found a great resource for OBDII codes.
Not only does it give you the description of the code, it also gives advice on fixing the problem.
http://www.samarins.com/diagnose/codes.html
Rob
lizard
Re: OBDII Codes
Postby lizard » Fri Apr 11, 2014 1:25 pm
:beer: :beer: :beer:
bootz
Re: OBDII Codes
Postby bootz » Fri Apr 11, 2014 1:46 pm
So they use the same code sequence for all makes and models and year of manufacture :?:
Sailor
Re: OBDII Codes
Postby Sailor » Fri Apr 11, 2014 5:34 pm
These are the generic codes that will cover most problems you are likely to see, there are other manufacturer specific codes
Rob
